Pulley Install On Engine Build
Old Sep 19, 2006 | 11:21 PM
SMonty's Avatar
Default Pulley Install On Engine Build
So my engine and transmission are separated as I'm rebuilding them both. Its time for the pulley to go on but the engine has nothing stopping it from rotating. What can I do to install the pulley without turning the engine over?
I have a compressor but I dont think using an air gun is a great idea.
Old Sep 19, 2006 | 11:37 PM
Ferocity02's Avatar
Put it on as far as you can, then just tighten it down all the way once you get everything back in the car. I wouldn't use compressed air. If you manage to get the piston to TDC with the compressor on the cylinder, the piston will go flying down and the wrench on the crank will fly off and probably hit you, very dangerous.
Old Sep 20, 2006 | 10:58 AM
Bad30th's Avatar
You might be able to bolt the flywheel to the back of the crank and use the teeth to hold the crank still while you put the pulley on - but you probably won't be able to torque the crank bolt to 240 ft/lbs with the engine out of the car...
Rob (Bad30th)
Old Sep 20, 2006 | 07:30 PM
SMonty's Avatar
Thats what I figured, ok thanks guys.
