How are GM and Ford MAF's different?
Old Sep 20, 2006 | 02:35 AM
V-10 Killer's Avatar
Default How are GM and Ford MAF's different?
I'm out of resolution with the MAF on my car (exceeding 11,250 Hz regardless of the amount of air/sec you put in the ECM). Has anyone ever tried fabbing up a Ford MAF to work in a GM car. How are they different?
Any electrical engineers out there that know how you could reduce output frequency on a MAF?
I really need to find a way to make a MAF operate at lower frequencies...
Old Sep 20, 2006 | 10:32 AM
Cop Car's Avatar
i have one ill sell you if you really want another one.
just have a speed density tune done
Old Sep 20, 2006 | 10:39 AM
slow's Avatar
You can run a ford maf on a GM car, you need to build a voltage 0-5 volt to frequency converter.
I have run a Ford lightning meter on my car to prove it could be done.
Ryan
Old Sep 20, 2006 | 07:17 PM
Unless yours won't make my ECM exceed 11,250 Hz, then it's no more use to me than my own 85mm SLP MAF.
I don't really want a SD tune mainly because I'm using a '98 ECM.
I have half of the resolution of a newer ECM in SD mode. And HP Tuners isn't planning on doing a 1 bar SD software tweak, that idea's out.
There's gotta be a way. There's some really damn smart people on this board, and apparently, slow is the only person that could pull it off (no offense man, we know you know your s#!t )?? I can't believe it's been 5 years since they stopped building them and nobody has come up with a fix for this yet
