o2 sensor and extensions Q's
1)is it ok to zip tie them to fuel lines???
2)im pretty sure its ok but just wanna ask..one extesion is touching the oil pan, itll be fine right??
3)i noticed that both o2 sensors are some what warm, car has not been turned on since last night. is that normal?
How warm is "warm"? They should be ambiant temp if the rest of the car is.
well lets just say that the header collector is cold and once you touch the o2 sensor you feel the diff. you could probably keep your hand on it for a bit w/out getting burnt
Did you have plug-n-play extensions or did you cut/splice your own?
plug-n-play extensions, i didnt check this morning before i left for work this morning to see if they were warm. ill check tomorrow morning.
any ideas to what could be causing this??
