Long Tube header ?s.
Thanks.
They all make about the same power, regardless.
Equal length tuned headers are pointless if they are all tuned to the wrong length.
Also every setup varies to what header will make the most power. Heads, runner, cam, valves, setup, tuning can all affect the outcome. So the same headers make work great on one setup and less so on another.
Personally unless you have lots of money or are in a race glass where you must extract every single HP I really wouldn't bother too much. Just buy a header with a good reputation:
Cheap ones (coated mild steel):
-Pacesetter
-Edlebrock
Expensive stainless steel:
-QTP
-Kooks
In reality they will all acheive very similar numbers on almost all setups. Not enough to worry about anyhow. Material is the only real difference, so just pic your price category and try and find the best deal there is.
If you wan a more technical writeup, read posts 6 and 13 in the exhaust/induction sticky. It's quite lengthy but very imformative.
There are differences in power. Different designs, different sizes, different collectors and different materials will make a power difference. Not just peak but a cross the board. We had a customer that had our old style collector and switch to our high velocity merge collectors gained 5 hp and 10-12tq. We spend many hours design our products and trying the make the most power possible. So please refrain from posting things like this when its is untrue.
Thank You
