Dyno tells flowmasters true flow.
And yeah...it's not a 30 hp difference, but pretty significant nonetheless especially since my car was stock back then!
Manny
Manny
Where both runs corrected to SAE?
All I'm saying is this:
Stock exhaust - - - - Flowmaster - - - - - Any other catback
<----------------------less than 30HP----------------->
...................................<--------------30HP gain--->
On a stock or near stock LS1 going from the factory exhuast to a catback or cutout won't net you 30bhp. So how can going from a better than factory exhaust (FLowmaster) to an alternative net a BIGGER gain?
Logically speaking something isn't right there.
Now I'm not dissing the claim or claiming bs. I totally believe the Flowmaster is a restriction on most LS1's.
But it's too often portrayed that if you have a lid + Flowmaster LS1 you'll gain near to 30rwhp by swapping to another catback. I personally feel this is very misleading.
I agree with you that the more you mod the car, the more of a difference the type of exhaust you have makes, after all, the engine is an air pump, but still, there was a significant difference between for me by swapping out exhausts. Needless to say I am happy with the B&B.
brody
All the Magnaflow talk is hearsay. It's no better than Hooker, GMMG, Corsa, either Loudmouth's...on a stock or bolt-on car, they all show about the same exact gains. It's not "one of the best flowing catbacks". It's no different than any other catback out there. The Flowmaster is an exception because it's a crossflow and things get diverted a little. ONLY the 80 series is in question, which is limited to f-bodys. Any other Flowmaster muffler (one or two chamber) will flow fine.
If you want "one of the best flowing catbacks," get a Loudmouth series or a GMMG. They're basically straight pipes. No muffler can outflow them. Magnaflow's good for the price, but I often find it's blown up into this incredible catback simply because it's immensely popular. Because of the price, so many people have it, it's blown up to be way more spectacular than it really is.
As for a magnaflow muffler, have you ever seen the inside of one? It's a straight through pipe peppered with holes. The holes divert sound into the muffler, which is packed with a packing material. Maybe steel wool, I forget. Well, this DOES disrupt flow. It's not a whole lot when compared to a chambered muffler like a Flowmaster, but it will definitely slow things down. Pair that with the split that has to happen - splitting the one inlet into two outlets - and you wind up with horsepower loss due to exhaust velocity being reduced significantly.
It doesn't matter that the Magnaflow is a "straight through" design. Magnaflow's definition of "straight through" is totally different than the "striaght through" found on an SLP Loudmouth catback. Plain and simple, SLP's design is better for flow and will generate more power 100% of the time in an apples to apples environment (same A/F ratio, same conditions, same car, gearing, transmission, etc...). At stock power levels, this is pretty negligible, but get into high horsepower levels and you'll get a much larger horsepower reduction through a Magnaflow muffler than through an SLP LM1. Why? Because horsepower gain and loss IS NOT linear. When the Magnaflow's limit approaches, the gains drop off like a rock. Straight through or not, the Magnaflow is much more restrictive than the SLP LM1 and you will approach the limit much faster.
Same principle with exhaust pipe length. Every foot of exhaust pipe you run will slow exhaust gases down more and more, robbing power. Limit the bends, limit the pipe length. Pipe is not perfect and its surface is full of friction. Flow isn't the only thing that determines a good exhaust setup. "Fluid mechanics" is a bad example because text book diagrams assume models are perfect. Real life is not like this. Real exhaust pipe is coarse and will slow down airflow more and more the larger the distance. Put in any kind of muffler and you slow it even more, regardless what type. Even a bullet will slow things down and cost you some amount of power.
Just because a system looks closest to straight pipe, doesn't mean it flows better in all circumstances than more conventional looking mufflers. The Hooker Aerochamber is a case in point. At appropriate power levels, its design approaches the efficiency of straight pipe. When the requirements of the engine are greater than its flow capacity, then of course power will drop off.
With that in mind, will a LM or GMMG produce more power 100% of the time than a Hooker or Magnaflow? No. Is there a point in power production where the latter would constitute a greater restriction that the former? Perhaps. It just depends on how much each flows.
Here are a couple of statements from David Vizard: "I am somewhat surprised that it is still commonly believed that building power and reducing noise are mutually exclusive. If we have a 2.5-inch muffler that flows 400 cfm, the engine reacts to this just the same as it would a piece of straight pipe flowing 400 cfm."
The full article is at: http://www.popularhotrodding.com/eng...exh/index.html.
