TSP Dual System
Old Sep 28, 2006 | 12:32 PM
crazylane's Avatar
Default TSP Dual System
I was reading on one of the threads that if you get a TSP system it would be wise to replace your Tranny Tq arm, that way you get better clearance on the TD's. Is this true or is it opinion only?
Old Sep 28, 2006 | 12:48 PM
TheBlurLS1's Avatar
That's what she said...
That's not even an opinion, it's flat out mis-information.
I had tons of clearance with the stocker. 99% of aftermarket TQ arms won't even work, much less be BETTER than the stocker. The UMI unit is specifically designed for them though (see sticky).
Old Sep 28, 2006 | 03:47 PM
crazylane's Avatar
okay thanks for the info, Greatly appriciated
Old Sep 28, 2006 | 04:03 PM
UMI Performance's Avatar
Thank you, and correct. A aftermarket torque arm is not a must at all with that system. If you do decide to swap out torque arms ours will fit nicely and allow you to tuck your TSP system up an additional inch.
Hope that helps
Ryan
Old Sep 28, 2006 | 06:27 PM
cws T/A's Avatar
mine clears fine
stock ride height
Old Sep 29, 2006 | 06:46 PM
crazylane's Avatar
Thanks for the info and pics guys, Appriciate it. This monday will be the day i order my tsp. Can't wait.
