All shorties bolt in ?
But shorties n/a is pretty pointless there's no real HP to gain by them. Just a lot of work to install.
Most bolt in with little fab and welding. My shorty Pacesetters bolted right up but I did need to weld a piece from the passenger cat to the header.
But seriously. For a n/a setup you might aswell stick with stock manifolds. You will see almost the same HP (1-2hp in most cases) as you would with shorties.
Scavenging is where the power is at, not flow. For n/a setups the stock manifolds flow plenty, espcially considering you wont be running a wild cam either in CA for the same emission purposes. Shorties don't scavenge in the operational range of the LS1, hence little or no gain.
If you go FI, the flow is what matters and scavenging doesn't take place. So shorties will pretty much match LT's when used with FI.
Scavenging doesn't take place when the intake air is being forced into the engine under higher than atmospheric pressure. So primary length of the header is not as critical. It's all about flow. Now some Lt's should out flow most shorties due to primary pipe diameter and collector size. But unless its one mean mother of a setup I doubt it would make many odds.
