Y pipe problem...
Old Sep 30, 2006 | 10:34 AM
99_Z_155's Avatar
Default Y pipe problem...
ok, on the drivers side of the y-pipe, i have a problem. the band clamp that holds the pipe to the collector is loose. the old clamp got rubbed so much that it split. i ordered a new one from tsp and torqued that bitch down on there tight. now its loose again. that side also hangs pretty low. what can i do to make it not rattle/leak at that connection?
Old Sep 30, 2006 | 03:41 PM
99_Z_155's Avatar
Nobody??
Old Sep 30, 2006 | 11:53 PM
Mean Green z28's Avatar
what kinda clamp you using? Get a band clamp (like they use on big rigs) from any autopart store, never seen one of them go bad and they seal positively when you put some RTV around the pipe joint.
Old Oct 1, 2006 | 12:15 AM
99_Z_155's Avatar
i have the big wide clamps...
Old Oct 1, 2006 | 02:58 AM
Starz T/A 17's Avatar
you cant try puttin some high temp lock tight on it
Old Oct 1, 2006 | 04:19 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Can or can't?
