H or X?
Old Oct 7, 2006 | 03:40 PM
1Last69's Avatar
Default H or X?
I know an X pipes gives a bit more power that an H, but not much. But the H has a better sound. So how much is "not much" power difference? I hate the rasp.
Old Oct 7, 2006 | 03:49 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not much is like 1-5rwhp max. Where are you in Saginaw? I live off Old Decatur.
Old Oct 7, 2006 | 09:57 PM
BrandonDrecksage's Avatar
well since sound is subjective..your better off listening to sounds and cars in person. This has been covered about 15 billion times...research a lil bit.
Old Oct 8, 2006 | 09:36 PM
1Last69's Avatar
Its typical, I get a smartass remark from someone about a question I didnt ask. I asked what the power gains were.......read a lil bit.
Old Oct 9, 2006 | 01:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would like to switch setups on my car. If you have an X and want to trade up for a y- setup I would be down.
Old Oct 9, 2006 | 10:03 AM
sicne your lazy and what not.....
https://ls1tech.com/forums/generation-iii-external-engine/531756-true-duals-questions-answered-here-post-your-information-pics-too.html
ITS A STICKY ON THIS PAGE.
Old Oct 9, 2006 | 05:34 PM
1Last69's Avatar
https://ls1tech.com/forums/showthread.php?t=531756
Q. What is better, X or H pipe?
A. Typically the X is known to put out slightly more power than H pipes, but not by much. The H pipe is known to have a better sound to it. You can’t really go wrong with either.
....like I said, how much is not much, Ive seen this sticky, and asked a further in depth question that was not answered. Do you like to argue or are you just trying to make yourself feel better about something? Now hurry along and go bother someone else.
Old Oct 9, 2006 | 08:34 PM
BlackHawk T/A's Avatar
Within the realm of 1-5hp.
Old Oct 9, 2006 | 09:23 PM
realistically...your not gonna get a real answer...besides the normal hear say. Next to no one has a h pipe on their fbody (assuming that is what your asking about..since you have one in your sig.) Most people go with a x pipe because that is what everyone else does and because the tsp dumped system only comes that way. So the few people that actually have that system would have to have had there cars baselined with a x pipe first(or vice versa) and then without any changes..and in the same weather..switched to a h pipe to see the changes in under curve area and peak power. So..that is why you won't find a comparable dyno fo the same car showing which is better...although a sponser I recall said that in the future they are gonna test the two back to back to get some results.
