stupid plug wire question
Old Oct 8, 2006 | 01:31 PM
Big Z's Avatar
Default stupid plug wire question
hey all, i changed my plugs and wires last week and the car has been bouncing back and forth between running good and running crappy. I kept noticing the wires keep coming loose, so i tried to take them off and put some more of the electric grease on them and two of them had the little metal clips inside break off! can i still use them or should i get new ones? theyre taylors and apparently nobody carrys them near here, im away from home right now. plus its sunday so theyre hard to find
Old Oct 8, 2006 | 04:08 PM
makWS6's Avatar
You need to put your stock ones back on and order some new ones. I had the same problem with my taylor 10.4 thundervolts and I just cleaned all the die-electric grease out, put a little on the contacts and not the rubber so it could stick on better. If you've broke your clips, you need new ones.
Old Oct 8, 2006 | 04:23 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Taylors seem to always have wierd problems like that. I have a set of MSD's that have never given me a hint of a problem. I need to have another set for my Z28 because the taylors are coming apart.
