True Dual X-Pipe setup VS aftermarket Y-Pipe setup...
Old Oct 12, 2006 | 04:55 PM
CaMaRo67RS355's Avatar
Question True Dual X-Pipe setup VS aftermarket Y-Pipe setup...
posting for a friend - ok i got LM1 right now and am trying to debate on what would i benefit the most from. the car will see a heads and cam setup SOON and will eventually see a forced induction setup (undecided on).
*which would pull more power out...
QTP's, ORY, & GMMG
OR
QTP's, no cats, 3" X-Pipe True Duals with Dynomax bullets?
*how much of a sound difference would there be?
*how much if any power can i be looking to gain depending on the setup?
Old Oct 12, 2006 | 06:56 PM
98camaroLS1M6's Avatar
QTPs with true duals will give more power, sound better with less rasp, but will be LOUD! If not worried about noise, go with true duals.
Old Oct 12, 2006 | 07:31 PM
2_wacko's Avatar
With those plans he might be better off with the true duals.
Old Oct 12, 2006 | 09:25 PM
landstuhltaylor's Avatar
true duals all the way
Old Oct 12, 2006 | 10:01 PM
bottledls1's Avatar
just run open heads!
Old Oct 12, 2006 | 10:03 PM
yeah im sure my motor would show me how much it liked that by dying. haha
Old Oct 12, 2006 | 10:05 PM
brad8266's Avatar
2.5 inch duals with either spiral flow mufflers or single chamber flows. Dual 3" is overkill, 2.5 is plenty.
Old Oct 12, 2006 | 10:10 PM
is 2.5 really that big of a difference compared to 3
Joey7489's Avatar
i run true duals, and ive got a local club where we meet up every thursday night.. ive gotten comments that my cars one of the best sound ls1 cars around.
mods in sig... in my opinion w TD's you CANNOT go wrong.. they muffle the exhaust just enough, to where its loud but not too loud, and they by far can put out the most HP. TD's are the least restricting exhaust in my opinion because theyre almost like running straight pipes with small mufflers.
TD's all the way
Old Oct 12, 2006 | 10:18 PM
Joey7489's Avatar
yes and no
under the car theres not really that much clearance, and depending on how much power you plan to put out is how wide youll want to go..This is the exhaust I have right now
It has 3" piping, and I really dont have clearance issues. Its really your choice man, Id say 3" just because itll support more HP, but 2.5 is plenty for like 400-500..
Old Oct 12, 2006 | 10:22 PM
i was looking at there kit and also the speed inc kit
Old Oct 12, 2006 | 10:55 PM
Joey7489's Avatar
TSP;s is direct clamp on and done..
speed incs needs alittle fabrication
its up to you
Old Oct 14, 2006 | 11:36 PM
wat kind of fabrication is needed?
