Spark Plugs
Old Oct 15, 2006 | 04:55 PM
JOHN LAWSON's Avatar
Default Spark Plugs
Any one ever use anti seaze on spark plugs in a ls1?
Old Oct 15, 2006 | 05:07 PM
v8's Avatar
v8
17,16,15,14,13,12,11 Drvr
put just alittle bit on the threads since the heads are alluminum it will help them from seizeing up when you need to replace them again.
Old Oct 15, 2006 | 05:14 PM
Some one put some on my plugs. They fouled out right away.
I just find it hard to understand that you can put a grease between an electrical connection and get a good connection.
Old Oct 15, 2006 | 05:16 PM
taintedmeat's Avatar
You put it on the threads, which are nowhere near any electrical connections....
And unless you like using a breaker bar to get your plugs out, especially the back 2 on the passenger side, you should really use it every time.
Old Oct 15, 2006 | 06:00 PM
BlackHawk T/A's Avatar
Definetely put some on the threads, but don't over-do it.
Old Oct 15, 2006 | 06:55 PM
Hell'sChariot's Avatar
yep.
aluminum heads its a must.
Old Oct 15, 2006 | 07:24 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Absolutely! AND, I always recommend a small dab of dielectric grease in both ends of the plug wire to prevent corrosion and lock out the moisture
