can a breather fit under a strut tower brace?
Old Oct 27, 2006 | 08:10 AM
pushinfreight's Avatar
Default can a breather fit under a strut tower brace?
did the search and did not see a definite answer to the question. If it cannot is there another way to hook a breather up to help with crank case pressure other than putting one in the oil fill location?
Old Oct 27, 2006 | 10:19 AM
sprydncamd ta's Avatar
they only fit with hotchkis stb i put a breather in the rear of my drivers side valve cover and i also switched to the ls6 style pcv system and im not pushing oil anymore on the 250 shot
Old Oct 27, 2006 | 05:25 PM
black01_WS6's Avatar
well I will be putting one on my car with my strut bar if I can get the dam chimney off the car- the black plastic piece the holds the oil cap. If you take that off it will fit in there.
Old Oct 27, 2006 | 06:31 PM
yes then you should get it in there you may have to add a rubber grommet around the hole i beleive that you have to take the valve cover off to take the oil fill out
Old Oct 27, 2006 | 09:11 PM
1999 SS's Avatar
i have a BMR stb and am using a breather on the pass side. the back side of the breather will rest against the stb but it shouldnt be a problem.
Old Oct 30, 2006 | 04:39 PM
can you get a pic of this?
Old Oct 30, 2006 | 05:00 PM
RICEETER's Avatar
i would also like pics and more info. i've been looking for one for my car for a while. does any of the sponsors sell one?
