Exact Steps for Intake Manifold Removal??
Note, that you have an almost 90% chance of breaking the Oil Pressure Sending Unit.
ls1howto.com says to disconnect the brakebooster hose (which is correct) but depending how it's snaked around behind the manifold, you still may have no clearance to pull the manifold out slightly before disconnecting the hoses/sensors.
I'd try to just buy one before doing the swap, it'll save you a lot of time trying to find one locally when you do break it.
