Do I really want to go 90/90?
your basically in a lose, lose situation...
3.42's are killing the power of that cam...
you go gears now... eventually when you blow your 10bolt you'll need to fork out more $$$ for gears to accomadate for a 9" or 12bolt
RrCoX22a Fast 90/90 setup is not going to help you any with your gears. if you get a new rearend, you will be able to taje advantage of the power your current cam makes. gears are around 300 bucks so that pretty much makes RrCoX22's post still valid. with a Fast 90/90 and gears you will have a fragile streetable car with around 500 RWHP that is not useable. with what you have and a 12 bolt you will have a car that is not fragile and still streetable and 500 RWHP that is useable.
