Modding Advice???
Old Nov 6, 2006 | 07:53 PM
Sonic28's Avatar
Default Modding Advice???
I have a '98 WS6. I am going to start purchasing some of the 'regular' bolt ons, along with a cam. Right now, I have shortie headers with no cats, and Borla exhaust. I just recently installed a new RAM HD clutch, pressure plate, along with a new stock flywheel. For whatever it is worth, I also have a WS6Store short shifter, with a HURST T-Handle, with roll control.
My question is mainly about the FAST intakes. I have seen the ones for a 78MM throttle body and for a 90MM throttle body. At some point, I will be changing the cam and possibly heads. Should I go with a 90MM throttle body and intake?
I know that there is no 'right' way or 'best' part. However, I would like to make educated decisions when purchasing my performance parts.
Thanks in advance for the advice!!
Old Nov 6, 2006 | 07:59 PM
Ego Killer's Avatar
IMO save your money on that fast setup.being that your a 98 go with an ls6 intake and ported TB I still have mine and its a mid/high 10 sec. car maybe do some 4.10 gears
Old Nov 6, 2006 | 08:01 PM
bayer-z28's Avatar
The FAST 90/90 is a bit overkill for a NON h/c motor, but would be more of a benifit once you DO add the H/C... The FAST intake make about (I think) 10 more HP over the stock LS6. I am not sure on what basis and mods they were comparing the manifolds on. You'd be sacrifising some HP until you get the H/C... if you were to do the FAST 90/90 before the H/C.
I have heard that the FAST 90/90 really shines when you Stroke/h/c...
I'd just do the LS6 for now... it'll be good for a while..
Old Nov 6, 2006 | 08:06 PM
01sscam's Avatar
Man-Crush Warning
Wait on the FAST 90 intake until you do the H/C package. Start with the Free mods, Lid, Longtubes, etc..
Old Nov 6, 2006 | 08:17 PM
Sonic28's Avatar
This is the type of information I was looking for. Thanks! Where would be the best place to get an LS6 intake?
Old Nov 6, 2006 | 08:20 PM
Sonic28's Avatar
Are there any websites that can explain how to 'port' a stock TB?
Old Nov 6, 2006 | 08:29 PM
bayer-z28's Avatar
Check EBAY for the LS6 Intake. Most of the parts vendors sell them too. Check on the main page w/ the list of vendors on the right.
Texas speed
Tbyrne motorsports
Afterthoughts auto -MIGHT have it
WS6 Store
Thunderracing
Speed Inc. /aka LS1Speed.com ($450 thru them)
Check www.Installuniversity.com They might have some info on it. You could also do the bump stop mod while you got that dremel and TB in your hand. -You'll need a multimeter for that, tho.
P+P INFO
http://web.camaross.com/forums/showt...le+body+advice
http://web.camaross.com/forums/showt...ting+polishing
http://web.camaross.com/forums/searc...archid=1294212
Old Nov 6, 2006 | 08:36 PM
Sonic28's Avatar
Thanks again!!
 Michael S. Palmer
Old Nov 6, 2006 | 10:42 PM
BirdmanLS1's Avatar
IF you are going to get H/C eventually then why waste the extra money on an LS6 intake? I am going to get the FAST 90/90 before i get h/c only cause i know ill be getting h/c eventually and i dont want to waste any money on something i know ill just replace later... just my opinion. You wont lose THAT much hp if anything with the 90/90.
Old Nov 6, 2006 | 11:19 PM
mike#9's Avatar
Get the Fast 90/90 setup. Especially cuz you will be going with a set of heads in the future to go with your cam.
Dont spend money 2 different times on intakes
Old Nov 7, 2006 | 09:28 AM
300bhp/ton's Avatar
FAST 90 with a NW or PTM TB (FAST 90mm TB is junk). This will easily out perform a LS6 intake by 15-25rwhp on a cammed or h/c/ setup. If you are serious about getting a cam or more, then I personally wouldn't waste money on buying a LS6 first. People who tell you different are generally trying to cover up because they didn't get a 90/90 setup.
Fair do a FAST 90 will only see minimal gains over a LS6 on a stock motor because a FAST 90 will show its abilities above 5500rpm and a stock motor is out of puff by 6000rpm.
But you won't loose anything by going FAST 90 it will just cost you double.
Texas Speed & Performance and Thunder Racing have most of what you'll need.
There's some more useful links in my sig also
