leaking coolant
Old Nov 8, 2006 | 10:33 PM
NviouSS's Avatar
Question leaking coolant
i've found a small amt of cooling collecting under the car lately. today, i had the front up on ramps but couldn't tell where the leak was coming from. a couple weeks ago i added some premixed dexcool to the radiator. could i have put too much in?
Old Nov 8, 2006 | 11:07 PM
Grimes's Avatar
if you really can't find where it is by just looking, you can get the flourescent dye and use a blacklight. Did you check by the water pump?
Old Nov 9, 2006 | 11:44 AM
NviouSS's Avatar
i've checked by both heads and the front when i was underneath and couldn't tell. if i do the dye thing, will it hurt the engine at all?
Old Nov 9, 2006 | 01:30 PM
joecar's Avatar
Check the weep hole on the water pump.
If it is the weep hole, you may also find orange coolant "residue" on the engine pan bolts (looks like orange grease).
Old Nov 10, 2006 | 12:32 AM
boochacas's Avatar
Ok I have the same problem and have the exact symptoms ( you may also find orange coolant "residue" on the engine pan bolts (looks like orange grease) so what does this mean?
Old Nov 11, 2006 | 04:43 PM
NviouSS's Avatar
where exactly is the weep hole?
Old Nov 11, 2006 | 09:24 PM
Shallow Bay's Avatar
https://ls1tech.com/forums/showthrea...ight=weep+hole
Old Nov 12, 2006 | 05:51 PM
427TWINTURBO's Avatar
the dye will not hurt the engine - have dyes for all fluids- oil, trans, coolant etc. works really well especially in tight spots where its hard to see specifically where its coming from & you can find the bottom of the "TRAIL" & follow it up
 Michael S. Palmer
one more thing look at the water pump notorious for leaking from the weep
Old Nov 13, 2006 | 01:50 PM
NviouSS's Avatar
got under the car again today. had it running this time. i found that the leak is coming from one of the bottom bolts. is this where the weep hole is?
Old Nov 13, 2006 | 01:52 PM
zrater's Avatar
water pump gaskets , hard to see but thats were its coming from
Old Nov 13, 2006 | 02:01 PM
NviouSS's Avatar
that's good to know. i have a replacement pump on the way just in case.
