Which header bolts???
Old Nov 8, 2006 | 11:49 PM
matt94z's Avatar
Default Which header bolts???
What does everyone use for header bolts? Stock, ARP, ect... I'm getting ready to put headers on my car, and want some good bolts that have clearance frpm the primaries. Stage 8 is out of the question, used them on a buddies Kooks install and thet are a PITA.
Old Nov 9, 2006 | 12:05 AM
BirdmanLS1's Avatar
I would recommend ARP bolts... I wish i had gotten ARP bolts when i did my headers.
Old Nov 9, 2006 | 12:10 AM
01350ss's Avatar
studs and nuts.
Old Nov 9, 2006 | 12:26 AM
Captainofiron's Avatar
I used Stage 8 locking bolts, I love those things, havent gotten loose on me once, and while yes it was a pain installing them, those things are never getting loose again
Old Nov 9, 2006 | 12:49 AM
SweeTbone's Avatar
I reused my stock ones and haven't had any problems yet. Clean the threads up upon removal and re-install.
Old Nov 9, 2006 | 01:05 AM
DONAIMIAN's Avatar
ARP only makes header studs for our cars and they run about 100 bucks a set. That being said, unless you just had the money burning a hole in your pocket, the sock ones would work just fine.
Old Nov 9, 2006 | 01:20 AM
michael402z06's Avatar
i put arp studs on myn and they are nice because its easy to install because you don't have to worry about lining the header up.
Old Nov 9, 2006 | 02:30 AM
RrCoX22's Avatar
stockers will do fine
 Michael S. Palmer
Old Nov 9, 2006 | 05:44 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It is bad enough getting all the crap out of the way of the header...studs seem like they would make it that much worse unless it was a conversion swap into a different vehicle and the coils were relocated. ARP studs run like 94.99$ at SDPC. But Stockers have always been the way to go.
