Pics of LM I or LM II Installation
If it's just configuration then the LM is top notch. The I pipe runs next to the propshaft, this is where the muffler is located, it's about 18-20" in length. It then goes up over the axle and immediatly splits via a reverse Y pipe into the two oulets.
Very easy install uses the factory hangers and fitted 100% first time.
The current LM's are modular so you can remove the muffler easier. My was the older style with a welded in muffler. But I doubt it'll make that many odds.
