How do O2 sensors work internally?
I've played with singe wire EGT probes that use two dissimilar metals to generate a small voltage (Mv) when heated, the voltage is simply feed to a voltmeter that is calibrated to display exhaust temp.
I know the three wire O2's are equipped with a heater (useing 2 of the wires), so that just leaves the one!
Are these O2's just as simple? ... 1002
Does anyone know the mechanics of how this O2 content is detected by the sensor?
I gota suspect it's some type of chemistry thing!
... 1002
[ November 23, 2001: Message edited by: cantdrv65 ]</p>
