Pacesetter specific LT question.
Old Nov 13, 2006 | 09:14 AM
Function>Form's Avatar
Default Pacesetter specific LT question.
does the driver side header toe outward a bit? towards the door? im looking at a set of Duals and the driver side pipe toes in before it gets to the header, and he said it was made for his pacesetter longtubes and that the pacesetter's are made that the driverside one toes outward a bit. is this true?
Old Nov 13, 2006 | 10:28 AM
Trent's Avatar
Yep sure is. Pretty much every LT I've seen for the LS1 does this. The driver side header outlet when mounted should point just about at the driver rear corner of the car.
Old Nov 13, 2006 | 11:38 AM
1slow98Z28's Avatar
has anyone heard that they are cheep and they will rust even the armor coated ones?
Old Nov 13, 2006 | 02:28 PM
Trent's Avatar
Armor coated? Not sure what that is but mine are ceramic coated and hold up perfectly fine. For those driving in colder climates where salt or sand is an issue, then a stainless header would be smarter, but I haven't heard of anyone having rust or any problems w/ the Pacesetters.
