painted headers better than coated!!
Chuck: Have you observed this on cars with hot exhausts, e.g. lots of back to back pulls? I wounder if it is a function of the greater mass of carbon steel & coating versus the stainless. Have you compared uncoated reagular steel with stainless?
thanks for the info man. i might have gotten mixed up.. thanks bro!!
Could also be that the coated do get hotter and transfer more heat to the head at the point of attachment rather than at the valves?
Time for some back to back experiments and EGT measurements.
now after reading all of these new posts that makes more sense. wouldn't have thought it would make that big of a difference.... but it would if you run the car lean up high instead of towards not as lean with whatever timing. it all depends on how you tune. each person has their own way that is different than everyone elses
It does not matter to me, if I ever decide to do headers I'll get 304 stainless anyway. The salt in the winter here will KILL anything else!
honestly though if I'm really considering that much of a budget header... I'd go the painted route because if I **** them up its just cheaper to replace down the road...
painted headers are for those who really have a tight budget and know the risks of using it...
for a long time there were only painted headers and a few stainless here and there, no one coated headers ... either didn't have the technology or didn't have the money for it in the first place.
I've seen firsthand the life of a painted header through a big block vs. a coated header through a big block ... and honestly, a big block pushing 650hp+ will eat up a pair of painted headers in no time flat in a place like houston, or seattle or anywhere there is a lot of moisture ... coated headers have a much longer life, but once that coating hits its limit, they're gone as well... thats when you get to that point of "meh, replacement time"
I was always taught that the coated LT's help keep the exhaust gases hotter in turn helping flow the gas out better & scavange better. I have NEVER heard of anyone having to change tuning for LT's especially pulling timing. The only reason to mess with the PCM after LT's is to delete the emmissions codes.
I have had my coated Pacesetters on & had the car scanned multiple times since the install. And never found a problem at all. I think something got misunderstood somewhere during the conversation you had. If you gotta pull timing after LT's then something else is going on with the car.
