Qeustion about pcv
Old Nov 15, 2006 | 09:19 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default Qeustion about pcv
do you run a breather or a catch can?
where the pcv line goes into the throttle body on the pass side if you disconnected that and plugged the nipple for the throttle body and put a breather on the pcv line wouldnt that keep the pcv system working properly and keep oil out of your intake?
Old Nov 15, 2006 | 09:51 PM
Luna's Avatar
Just remove the PCV system altogether, run 3/8" hose from valve cover to valve cover , cap off all the lines and get a breather for your oil filler cap.
You're oil consumption issues will be solved
Old Nov 15, 2006 | 10:32 PM
zspot98's Avatar
What do you do w/ the line from the valve cover to the TB?
