m/a n t/b?
Old Nov 19, 2006 | 02:19 PM
j's02ws6's Avatar
Default m/a n t/b?
would a 90 mm m/a n t/b cause any kinda of problems on a stock 02 ws6?
Old Nov 19, 2006 | 08:52 PM
HeapaShifter's Avatar
90mm m/a n t/b?
Do you mean 90mm intake manifold & throttle body?
It would be overkill for a stock engine and you'd just end up loosing torque.
Old Nov 19, 2006 | 08:55 PM
Tainted's Avatar
no, but as it was said already its not gonna do much. an intake that big on a stock motor wont loose torque, but will put it way up hih in the rpm band where you cant get to it. a LS6 intake is more than adequate,e ven on soem head/cam cars. a 90mm tb is worthless as well w/o you have a real need for it. a ported stock TB for 75$ from a sponsor will give about the same gains for far less
Old Nov 20, 2006 | 04:07 AM
300bhp/ton's Avatar
If you plan on h/c or just a decent cam then go for it. But the FAST 90 really shines above 5500rpm so on a totally STOCK internal motor you'll see next to no gain, dust a dent in your wallet.
To see the benefit otherwise you probably need to be spinning to motor up past 6400rpm, or have bigger displacement. Or maybe a decent FI setup.
