Holden intake fit to LS1?
Old Nov 20, 2006 | 10:34 PM
99_Z_155's Avatar
Default Holden intake fit to LS1?
ok, i work at a chevy dealership, and our performance guy said he had a deal for me. he has the holden intake, which is the ls2 intake, that includes the fuel rails, injectors, sensors, and 90mm TB. now i know that the TB wont work, but will the rest of that work? and if so, does this intake perform similar to the LS6 intake? i tried the search, but its not working. and in case you are wondering, all this comes pre assembled, and my cost is BELOW 400 for everything
Old Nov 20, 2006 | 11:02 PM
Divergent Lightning's Avatar
might be worth to buy then chock on ebay for a little more, but otherwise it is more hassle than it would be worth.
Old Nov 21, 2006 | 08:43 AM
Cop Car's Avatar
sounds like he is describing the L76 intake. it will not work on LS1 heads.
and before you ask L92 (this is what L76 intakes go on) heads do not work on LS1s.
Old Nov 21, 2006 | 01:58 PM
Bader-X's Avatar
he is describing the ls2 intake injectors ect.. not the L92 or L76intake ...
Old Nov 21, 2006 | 02:58 PM
99_Z_155's Avatar
BTW, the PN for the intake is 12590123. and i just found out that that is for the L76. he also offered different heads with the PN 12582713. i assume they will mate with the intake....
Old Nov 21, 2006 | 06:16 PM
HeapaShifter's Avatar
ditto
Old Nov 22, 2006 | 01:56 PM
Cop Car's Avatar
i was right.
and yes the intake and heads work together. but you cant use them on a motora with less than a 4.00 inch bore, which means you would have to buy an LS2/7 or LQ4/9 block to use those heads.
