90mm Throttle Body Spaceer... worth it?
Old Nov 24, 2006 | 02:29 PM
C5 Forever's Avatar
Default 90mm Throttle Body Spaceer... worth it?
Do you really see any gains out of adding a throttle body spacer?
Old Nov 24, 2006 | 03:22 PM
Ragtop 99's Avatar
If you look around, you won't see anyone fast who is using a TB spacer, so that should be your guide.
Old Nov 24, 2006 | 03:24 PM
Doore39's Avatar
I was always told that tb spacer were a waste they only work on carburated engines since it gives the air/fuel more room to mix.
Old Nov 27, 2006 | 04:16 AM
TryingT/A's Avatar
Yeah, I don't think it would be worth it either. The spacers have the grooves that are supposed to spin your air sort of like the tornado fuel saver, but I don't think it would make any sort of a difference. Money would be better spent elsewhere. Oh and that tornado fuel saver only gives you better gas mileage 'cause it restricts any air coming in
Old Nov 27, 2006 | 04:43 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Don't do it. It will get you no where FAST.
