oil pan
Old Nov 25, 2006 | 04:46 PM
george88gta's Avatar
Default oil pan
Are the oil pans interchangeable between a 2002 6.0 and a 2005 6.0? They have different part numbers. I will be modiying the pan and pickup for steering linkage clearance, so my main concern is bolt pattern and matching up to the 2002 block.
Old Nov 26, 2006 | 10:33 AM
WILWAXU's Avatar
Should bolt to the block. If the shape is different, be sure to use the correct pickup for whatever pan you use.
