402/408 guys in here!!
Old Nov 25, 2006 | 10:21 PM
marine02ss's Avatar
Default 402/408 guys in here!!
My mods are in my sig,I currently have a 3"single y pipe into a 12" bullet muffler,dump half way.My ? is will I gain anything at all going to a x-pipe and dual 12" bullets.Power wise or ET wise.I want more ET,just having the debate whether or not its worth the hassle of doing it.Any experienced users out there??
Old Nov 25, 2006 | 10:50 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
6 of one half dozen another. You will have the y-pipe lovers tell you to stick with what you have and the true dual fanatics say to switch. Personally I think I picked up power with the td setup that I currently run. It is going to be an all out "flow rate battle" up in here though. I think that you will be putting down enough power to use past the 100% of the Y-pipe. And Around 85-90% of the X pipe. Bottom line.
Run the X setup.
Old Nov 26, 2006 | 02:31 AM
TheBlurLS1's Avatar
That's what she said...
OR you could run a 4" I-pipe and a cutout.
See sig......
