what is the difference between a ported M.A.S. and not...???
Old Nov 28, 2006 | 11:03 PM
CaMaRo67RS355's Avatar
Question what is the difference between a ported M.A.S. and not...???
-i know the difference between a screened and descreened M.A.S. but when someone says mines ported what does that mean? ive seen ported M.A.S. ends is that what they mean?
-also while your here when someone says there air and egr system have been removed that means wat? im confused by some stuff ive read and wanted to know the truth. egr came on the 98,99, & 00's right?
Old Nov 29, 2006 | 05:25 AM
300bhp/ton's Avatar
Ported MAF (Mass Air Flow) means someone has too much time and too little money. They basically hack away all the fins on the MAF in the belief it will make their car faster.
Installuniversity.com has a write up and pics on it.
As for AIR/EGR. These are emission control systems.
EGR - 98-00
AIR - all models
EGR is exhaust gas recirculation. An inert gas (in this case exhaust gas) is feed back into the combustion chamber. This has the result of lowering PEAK combustion temps and thus reduces NOX emissions. The system is not active at WOT (wide open throttle). So cost you zero HP.
People remove it because it cleans the engine bay up. Save some weight (small amount) and means you can run non emissions exhaust headers and intake manifold without needed to block the ports off. If you don't plan on running cats there is zero point in keeping the EGR.
AIR - This is a small air pump which pumps outside air into the exhaust system on start up. It typically runs for 20 seconds to a couple of mins. It is there to help promote the chemical reation in the CATs and reduce emisisons after start up and before the cats have warmed up. It exists to pass the start up emissions standards. It also costs zero HP.
You can remove it for the same reasons above.
If you do remove them, you PCM will throw a code. This can be deleted by tuning software or handheld devices.
Old Nov 30, 2006 | 06:39 PM
GuitsBoy's Avatar
Sorry, 300BHP, Im going to have to state my differeing opinion - atleast with a qualifier.
Im a big fan of the ported MAF, as long as you have the means and the patience to properly tune it. People regularly see gains from a ported throttle body, yet the MAF is even more of a restriction. I hogged mine out an extra 40% vs. stock (judging by maf tables). The car idles and drives much better with teh MAF than it does in SD mode. It also eased my cam bucking.
If youre thinking about porting it on a stock car, it surely isnt worth the trouble. However, once youre talking about heads and cam cars, IMO, the MAF does become a noticeable restriction. Even if it dosnt limit you (hitting a wall) theres still free/cheap horsepower than can be found there. Yes, you can accomplish the same thing by going SD and running big drain pipe in its place, however I feel the car is easier to tune, drives better, and reacts accordingly to weather changes with the MAF.
Old Nov 30, 2006 | 07:11 PM
slick1851's Avatar
Do the free ramair mod, gutted air box and find a nice used Lid
Old Dec 1, 2006 | 05:03 AM
300bhp/ton's Avatar
To be honest I can't disagree with any of that. Nice post :thumbs:
Old Dec 1, 2006 | 09:21 AM
Torque_Wrench's Avatar
I agree with the porting of the MAF...but the 1 to 3 HP increase is very nominal. But I do support porting your MAF instead of buying a Granatelli or Jet MAF.....because I think they both are a waste of money.
