Finally did the LS6 intake swap!
Old Dec 4, 2006 | 04:39 AM
matt94z's Avatar
Very nice gains! Did you have it tuned with the LS6 intake on or was that just bolt on and go to the track?
Old Dec 4, 2006 | 09:14 AM
TheBlurLS1's Avatar
That's what she said...
Here's my injector clip removal method.
1st) Stick screwdriver in between plastic and metal clip as shown
2nd) Pry the clip down untill it pops over the "hump" and slides down 3/16" or so.
3rd) Slide metal clip rest of way down on ONE SIDE only.
4th) At this point, you should be able to remove the connector from the injector.
5th) Simply click the metal part back into the original location. This will keep it from getting lost, or worse, falling into a port on the head. You can just click the plugs back onto the injector on re-install and don't have to worry about popping it out again.
Hope this helps for next time...
Old Dec 4, 2006 | 09:55 AM
NOBR8KSS's Avatar
I'm about to do this intake swap myself, and this post has been really helpful...thanks!
Old Dec 4, 2006 | 11:33 AM
Sk8runeg's Avatar
lol you realize you can just push in on rounded part of the metal clip and it spreads the sides apart so you can slide the plug off.
Old Dec 4, 2006 | 01:53 PM
TheBlurLS1's Avatar
Didn't know that, but I'll try it.
I imagine it's pretty tough to push them when they are squeezed inbetween **** and way up under the cowl. I can do them fast with the flathead.
Old Dec 4, 2006 | 02:10 PM
68birdls1's Avatar
no way man, yea all you do is push in on that little lump and it just spreads them right apart and pop off the clip. i was really surprised when i found that out on my 94 camaro when i did heads and cam.
Old Dec 4, 2006 | 04:56 PM
deadmanTA's Avatar
Red99TA, DOUBT IT
Thanks for the priceless info.
Old Dec 4, 2006 | 06:19 PM
TuffSS's Avatar
I believe the differences from LS1 intake to LS6, but I do wish I had a couple of pics showing them side by side. Nothing like seeing it! The intake swap is getting higher up on my priority list after reading this though.
Old Dec 4, 2006 | 06:20 PM
DOUBT IT's Avatar
matt94z: The car already had a tune, and has not been tuned since the install of the intake. I don't think that it needs one, or if it does, I'd be scared to see how much it would gain with a tune. I think that it's fine as is. I certainly don't hear/feel any detonation.
Blur: that's basically what I did, just with a hook pick, and I took the clip all the way off and laid it on the air filter.
I'm glad that my install is actually helping someone, I didn't think that it would. I just posted the pics really to show how dirty it was under the damn intake.
Old Dec 4, 2006 | 07:02 PM
bad6as's Avatar
when reusing the older style crossovers on the ls6 im. your just grinding off the pattern or do you cut in the bottom of the im some?
Old Dec 4, 2006 | 07:25 PM
DOUBT IT's Avatar
Just grind the ribs!!!! (DO NOT GRIND OFF THE BOTTOM OF THE INTAKE!!!!!!)
Old Dec 4, 2006 | 08:25 PM
  #32
matt94z's Avatar
[QUOTE=DOUBT IT]matt94z: The car already had a tune, and has not been tuned since the install of the intake. I don't think that it needs one, or if it does, I'd be scared to see how much it would gain with a tune. I think that it's fine as is. I certainly don't hear/feel any detonation.
Cool, I'll be doing my swap as soon as I get the Emmision stuff turned off so I don't have any codes.
Old Dec 4, 2006 | 08:30 PM
  #33
Sk8runeg's Avatar
Ya not trying to offend you in any way, just saying the way I always thought was easiest. But hey if it works dont fix it!
Old Dec 4, 2006 | 09:41 PM
  #34
ULTIMATEORANGESS's Avatar
Good numbers! MPH gains are always good.
You need to check your sources..... and by check I mean kick in the *****....
Old Dec 4, 2006 | 11:04 PM
  #35
Justin00SS's Avatar
I love mine. 3.5k+rpms and she screams!
It took my car about 2-3 days of driving for her to find the right idle rpm though.
She would sit at ~850-900rpms after the intake install. Now its back to stock.
Did anyone else notice this?
Old Dec 5, 2006 | 11:57 AM
  #36
bayer-z28's Avatar
Originally Posted by DOUBT IT
Umm... no. The LS6 is very different. The runners are a lot larger, the bottom is a ****-pile deeper, and the internal structure is quite a bit better designed. If you saw the two side-by-side you wouldn't make such a statement.
I myself was surprised at the difference when I pulled the LS1 off and sat it next to the LS6. I knew I should have taken pictures for you guys.
The average gain IIRC was about 10-12 rwhp. Of course, that is a static gain, and doesn't take into account cars like mine with free-breathing intake tracts that gain horsepower as they get moving.
But if you want to stay slow, just keep that LS1 intake.
There's a big diff between the manifolds. I've been wanting to do this for a long time. I did the intake gasket on my cousin's dodge this weekend, that was easy. So I figure I can handle the LS6 Swap.
Old Dec 5, 2006 | 07:28 PM
  #37
DOUBT IT's Avatar
Compilation of me and Ele-Blue95 running on Sunday. Hope you like.
Click here to see Video
Old Dec 5, 2006 | 07:29 PM
  #38
lastcall190's Avatar
Do you have a DL'able file by any chance? My slow as **** internet doesn't like to stream.
-J
Old Dec 5, 2006 | 07:35 PM
  #39
DOUBT IT's Avatar
-J
Not unless someone is willing to host about a 16 MB file. I could always mail it to you. PM me with an email address...
EDIT: Put it up on yousendit.com... It will be there for 7 days. If you want it, get it. http://download.yousendit.com/16C11E5140896BD1
lastcall190, you have mail
Old Dec 5, 2006 | 08:08 PM
  #40
Thanks man just got the email and DLed it. Good vid! Seems pretty damn fast for bolt ons to me! Specs on that LT1?
-J
