ls6 identification
Old Dec 3, 2006 | 03:22 PM
phoenix305's Avatar
Default ls6 identification
how do you tell if a manifold is ls6 or not?
Old Dec 3, 2006 | 03:25 PM
blkbird's Avatar
search....... it should be working right now.
Old Dec 3, 2006 | 04:00 PM
v8hunter's Avatar
Most of the ls6 manifolds do not have egr and the bottom is flat instead of curved. Also if the throttle body hole is much bigger it is likely the ls2 instead.
Old Dec 3, 2006 | 05:29 PM
2001NBMZ28's Avatar
Look for a PN to be sure, they've changed over the years but you can still search it. My stock LS6 PN is 12561184 and located on the drivers side.
Old Dec 3, 2006 | 06:16 PM
Blacker's Avatar
All LS6 Intake Manifolds do not have EGR and they are flat on the bottom.
Old Dec 3, 2006 | 11:03 PM
TheBlurLS1's Avatar
That's what she said...
Some of the SLP LS6 manifolds did have EGR. Some of the LS1 manifolds DON'T, so the EGR hole is not a very good thing to look at.
The flat bottom is the dead giveaway however.
The LS2 manifolds has a 4 bolt, 90mm opening. LS1/LS6 is smaller and has only 3 bolts for the throttle body.
