intake question?
Old Dec 8, 2006 | 02:00 PM
jegan1989's Avatar
Default intake question?
is there a way to set up a intake or intakes to have 1 run 4 cylinders and another one to run the other 4 or is there a way to run two intakes or is there a set up like i stated i wanted at the top
thanks joe
Old Dec 8, 2006 | 02:01 PM
ls1_doc's Avatar
I really doubt it because there is only one intake into the motor. Why would you want to do that ?
TheBlurLS1's Avatar
That's what she said...
You would need an individual runner setup, but I've not seen one that divides them in two. With a conventional manifold, you would not be able to do this.
Search for the Harrop intake and see if you can find some info.
Old Dec 8, 2006 | 03:24 PM
jegan1989's Avatar
HARROP HURRICANE IT HAS 8 INDIVIDUAL 55MM THROTTLE BODYS
or a sheetmetal intake would one of them work
check my post under d1sc procharger towards the top and you will find out y i want to know
thanks joe
Old Dec 8, 2006 | 07:32 PM
jegan1989's Avatar
does anyone know
