What is that sound a Magnaflow makes on decel??
http://ls1sounds.com/magnaflow/magna..._JetHotORY.wmv
My Corsa does it under certain conditions. A friend had the exact same setup as mine but on an A4 and did that a lot more. I've heard another car make the same sound as mine and it turns out he had the same kind of setup with a Borla C/B.
uh, no sir.
I've had both, you are comparing an open cutout to magnaflow? It just doesn't work like that.
As for the sound. No it is not rasp. It is the exhaust depressurizing. All free flowing exhausts do it but the sound is more pronounced through an ORY, especially without cats. As for it sounding like hell, maybe if it's not setup correctly. First, almost all off the shelf y-pipes blow chunks. Check out the merges, especially on the inside and you'll be quite suprised. Get a custom one. After having a custom y made and getting most of the exhaust welded up the tone of my exhaust (Magnaflow, Jet hots, no cats) completely changed. Will never sound like a true muscle car but sounds damn good with little rasp, no popping, or mechanical sounds.
The blaaaah sound when the revs are dropping smoothed out alot and sounds more throaty.
http://www.blackz28.com/Vids/Long%20Revs.wmv
As far as having one custom made, how is the merge in the ones off the shelf different from one I would have made? How would I know wut to tell an exhaust guy as far as how I want it made? Im guessing I couldnt just trust any exhaust shop to fabricate one for my car that is decent.
