tips for installing y pipes?
Old Dec 14, 2006 | 11:42 PM
sidewayz28's Avatar
Default tips for installing y pipes?
well THE VERY LAST thing thats stopping me from driving my car right now is getting the y pipe all the way back on the collectors, (which will let me slide it back on the I pipe)...anyone have any tips? i know alot of it is just muscling it back into place.. i was using a little WD40 around where the ypipe sits on the collector and using a malet.. but unfortunately the malet broke in half . so what are your proven methods / tips?
btw: pacesetter LTs -> TSP catted Y
Old Dec 14, 2006 | 11:45 PM
Starz T/A 17's Avatar
Its ALOT easier if you drop/loosen the muffler assembly
Old Dec 14, 2006 | 11:54 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Leave everything loose as you put it up there, and of course loosen the Catback.
I pull both hangers at the rear, as well as loosen the clamp at the i pipe/over the axle pipes.
I nice 5 pound rubber mallet works. I also always use a little emory cloth, or 90 degree grinder withe a 3M pad and clean my mating surfaces up. Add some silicone spray and go at it.
A prybar and a rubber hammer get the job done with have the strain. If you don't have the tools, I don't know what to tell ya.
At the least, clean up all your surfaces. It takes a bit of muscling, but you'll get it.
Old Dec 14, 2006 | 11:59 PM
sidewayz28's Avatar
hmm my i pipe is not upright.. its hanging down.. so you suggest i loosen up the clamps holding my C/B up?
Old Dec 15, 2006 | 12:06 AM
sidewayz28's Avatar
its not that im having problems with the I pipe.. i have the Y connected to the collectors, i just need to slide it up another inch. i think ill try backing it out, cleaning the surfaces, and try sliding it back into place?
Old Dec 15, 2006 | 12:26 AM
00formLs1's Avatar
i used the oil filter wrench that has a chain on it to move it in to place. also a rubber mallot
Old Dec 15, 2006 | 12:55 AM
SweeTbone's Avatar
I used a piece of wood around 2 feet long and laid it against the Y-pipe. Just tapped on the block and it pushed the Y-pipe further up the collectors.
Old Dec 15, 2006 | 08:27 PM
Cstick's Avatar
I searched for an exhaust pipe expander but I could not find one to do 3", just 2 1/2. It would have really helped me.
Old Dec 16, 2006 | 12:36 AM
sidewayz28's Avatar
i fucken hate exhaust it makes me want to cry
