Only god can help me now!! Or can you?
Old Dec 22, 2006 | 04:00 AM
kawasakiklx's Avatar
Default Only god can help me now!! Or can you?
I am getting ready to install my engine but need help with a few loose items.
I am having problems with those hard plastic lines on the D/S of the intake area.
The plastic line to the d/s of the intake is fine but the other is broke.
The main terminal in the rear has 2 connections referred labeled as 3 in the pictures ...one going to the rear of the intake Labeled as 1 in the pictures and the other is broke Labeled as 4 in the pictures. Where did that broken line go?
The terminal in the intake also looks like it accepts and additional line facing the passenger side but there is no line hooked to it labeled as 2 in the pictures. Where does that go?
Since I am probably confusing you I have attached pictures to help you understand what I am asking.
The best thing would be to obtain part numbers to replace these pieces of ****. If I can somehow delete them, let me know how. Thanks ahead of time.
Pictures:
Should be 3 different pictures attached, labeled with extreme kindergarden style numbering... haha
- Labeling remains constant throughout all 3 pictures.
THANKS!!!!
P.S. If ya'll respond with the numbers that would be awesome. Don't worry you hate me, I hate myself
Old Dec 22, 2006 | 05:49 AM
Brent@LPE's Avatar
PM sent
Old Dec 31, 2006 | 04:16 AM
Answer found the 98's don't have any of that bs 1,2,3 or 4. I just pulled the T off and the single outlet goes to the connection near the PCM. God I was confused!
Old Dec 31, 2006 | 07:16 AM
Raise's Avatar
i was gonna say, all that goes to the AIR system on 01-02 cars. good deal man
Old Dec 31, 2006 | 07:24 AM
cowboysfan's Avatar
yup! air system stuff. I plugged mine up and removed lines that dont need to be there. if I remember right evaperate fuel system lines.
fuerzaws6
Old Dec 31, 2006 | 07:32 AM
This is what happens when you put a '00 engine in a '98 with a newer LS6 intake. Now I just have to figure out the cam sensor wire colors for my red headed step child 98 PCM.
