Under drive pulleys
Old Dec 22, 2006 | 08:22 AM
1hotls1's Avatar
Default Under drive pulleys
Just wondering if they are worth the money and if they cause any overheating issues or A/C problems in the hot summer months? I've heard that they are worth about ten rwhp, but don't want a lot of side effects.
Old Dec 22, 2006 | 09:20 AM
koolaid_kid's Avatar
This is a very controversial question. You will find all sorts of opinions. I have one on mine. Never had an a/c or temp problem. However, I was sitting idling at the track while they cleaned up the track from a car that dropped its load. My battery discharged and I had to get a jump. I then put an overdrive pulley on my alternator and have had no problem since.
As to the value, well, I like mine. I doubt, however, that you get a full 10 hp. Most add-ons exagerate their hp gains, note they say "Up to xx hp".
Old Dec 22, 2006 | 09:59 AM
bayer-z28's Avatar
I asked a similar Q on CZ28. I heard people w M6 had no problems at all whereas the A4 guys had charging issues. Some pulleys offer a kit w/ an OD pulley for the alternator.
Old Dec 22, 2006 | 10:06 AM
staringback05's Avatar
there deff. not worth the 200+ dollars slp and others try to sell them for, however if your doing internal mods and can get one for around 100 bucks its not a bad mod, also if you can get the pulley for the Alt. that would be a good idea also....it will take a bit of strain off your motor and free up some power
Old Dec 22, 2006 | 10:18 AM
white_camaro's Avatar
a solid .1 and mph with mine. had the idle raised so no issues there.
Old Dec 22, 2006 | 10:29 AM
Grimes's Avatar
have to disagree with most here - no problems with mine in over two years, and I really did feel a good difference. Totally worth the time and money!
Old Dec 22, 2006 | 10:31 AM
bad2000z's Avatar
I have had my ASP crank pulley for 4 years with no problems. I did throw my serpentine belt at the track once, but I think it was due to high rpm's and the stock tensioner, not the pulley.
Old Dec 22, 2006 | 12:06 PM
Blacker's Avatar
I have had my ASP Crank U/D Pulley for 6 years and have experienced no side effects of it. It is a worthwhile part and I highly recommend it.
Old Dec 22, 2006 | 12:49 PM
BitViper's Avatar
which is best teh ASP or teh SLP
Which one has the lip
Old Dec 22, 2006 | 12:54 PM
we_todd_did's Avatar
**** I have a ATI 60% underdrive and have no problems.
Old Dec 22, 2006 | 01:35 PM
HAMRHEAD's Avatar
I had an ASP underdrive pulley and never had any problems. I use an ATI now which is the best IMHO
Old Dec 22, 2006 | 01:46 PM
SEB's Avatar
SEB
I asked this same question before I bought mine. I was running a best of 7.47 @ 91 mph before Pullys & EWP
After the install of ASP Pully & EWP I ran a best of 7.26 @ 94 mph. So I disagree with the haters
Old Dec 22, 2006 | 03:28 PM
i like slp/powerbond because of the high retension walls to prevent belt slip.
Old Dec 25, 2006 | 02:30 PM
lsx24's Avatar
Also I heard some pulleys don't clear the double roller timing sets...I think it was powerbond and SLP that don't require machining iirc...
But overall a pulley is worth a solid 10 rwhp 10 rwtq. Not sure about the Auto thing though...they tend to idle lower in gear because of the stock converter tightness, and the ones in this thread who have a pulley and auto all have aftermarket converters
Old Dec 25, 2006 | 02:44 PM
The1N_only's Avatar
it was the ASP pulley that didnt clear a while back, they were supposed to have corrected that problem a while back. I guess ill find out when i go to put a cam in my car lol
The1N_only's Avatar
I have one sitting in my garage if anyone wants it
Old Dec 25, 2006 | 04:31 PM
ASkipper's Avatar
How much?
Old Dec 25, 2006 | 04:45 PM
The1N_only's Avatar
PM sent
