Pacesetter header install with ramps
when i did mine i put the rear tires on the ramps and put the jackstands under the front on their second to highest setting....
u will also need cinder blocks to stand on to acess the engine bay...
i actually pulled mine on ramps and then jacked it up(easier w/floorjack), but its only a few inches higher and you can get enough clearance. jacking up the back is not necessary.
The K-member at its lowest point was 18 inches off the ground.
The only jack stands that I used were placed just behind the front tires on the sub-frame and were at there highest notch, approximately 17 inches.
My hanging tire was 8.5 inches off the ground.
The rear tires were left on the ground.
My passenger side header slid in with no effort and so did the driver side.
All spark plugs were removed as well as the steering shaft. I also had the coil packs and valve covers off.
I had no EGR or AIR provisions on mine (not sure if it makes a difference) and I also removed the heat shield on the passenger side to allow more room(probably not necessary)
With all this done I was able to install the headers by myself and get all header bolts in with the use of a small socket wrench and 3/8" socket.
Use a little piece of scotch tape to hold the gasket to the header while you get a couple header bolts started, then remove the tape.
I have to admit that I was a little scared about the install after reading some posts, but I had no fittment issues and it went really smoothly.
