cutout outs good or bad?
i also get around 2mpg worse with it open, all interstate driving.
That is DEAD WRONG. Keep telling yourself that if it makes you feel better. I suppose the drag cars that are LS1's all have mufflers and duals ran out the back.
You may lose a little powe down low, but the gain up top where you need it if you are racing will make up for it.
I don't think it's enough of a difference for me.
To have a loud *** exhaust all the time.
To scrape on every speed bump driven over.
To win a dyno shootout for torque below 3,000 RPM's
I'll stick to enjoying having a really quiet........to loud as hell exhaust in 5 seconds.
1). An all-out drag car makes it's hp in the UPPER rpms, much different that an ls1, relatively speaking. We're talking over 7-9k rpm here, minimum, so you can't really compare it to the design of an engine that has an operating range of 2-6.5k rpm.
2). A all-out drag car doesn't need to have mufflers and piping, just not required with their packaging constraints. So even if it was no hp loss to run true duals and mufflers, they don't need to do so.
but most importantly,
3). We are talking about ZERO-backpressure systems. A cutout runs with Zero backpressure, that's how it makes a handful of hp more than a catback system. But so does good designed True Duals, run at ZERO backpressure. so their top-end hp potential are the same. HOWEVER, a cutout can't scavenge, therefore will never make as much power as true duals, unless the engine is designed to operate in that range (see above reason).
1). They are no louder than having a catback on a regular car, when run out the back and through a full-size muffler, like the Bassani system or a custom one just like it, a preferred configuration of those who are after duals that are refined.
2). They don't hang any lower than a ypipe system, if designed and built WELL, which you should pay for if you are getting True Duals.
3). They don't make tq below 3k rpms, they make more tq right in the meat of the powerband, as is proven my my dyno graph (and others) when switching to true duals from a ypipe configuration:
4). IMO cutouts sound like *** definately WORSE than a fantastic sounding True Dual Exhaust system (which is music to the ears).
LMAO!! i couldnt have worded that any better myself! that is my main goal with my cut out lol! I LOVE IT
The before-run was with stock cats and ypipe, with Magnaflow catback.
BTW, this is with stock maniflods and y-pipe.
Why is anyone worried about getting bad gas mileage. That is almost a sacrifice for power. I didnt buy mine for the gas mileage.
But its still not loud enough, im hoping headers and ory that i just got will solver that problem
I'm going to have it re-dyno'd this spring, numbers below are though the stock exhaust and stopping the pull @ 6K. Can't wait to see what numbers she put's down w/open cutout screaming @6700 rpm.
