SSRA ...to seal or not to seal?
Old Dec 27, 2006 | 08:00 PM
Magnet's Avatar
Default SSRA ...to seal or not to seal?
hey do you guys think i should seal off my SS hood with the SSRA or not? it doesnt make very much sense to me to black it off, because it seems like the more air the better...but i know for some reason they say you should? let me know what you think and WHY
Old Dec 27, 2006 | 08:37 PM
CJDZ24_Z28's Avatar
I sealed mine. I have a Whisper Cold Air Scoop on my SS but Im ordering a SSRA for my B4C. I sealed mine because i figured the little air that the SS hood flows isn't nearly as much as the cold air scoop.
Old Dec 27, 2006 | 08:39 PM
iamsickofitall's Avatar
the SSRA will suck more air than the hood scoop. air that could be going to your intake will be bled out of the hood scoop if it's not sealed up
Old Dec 27, 2006 | 09:36 PM
bayer-z28's Avatar
That hood scoop flows pretty good. I did and experiment w/ an air hose and foot powder.. But it does NOT feed directly to the airbox. A lot of room for it to bleed out.
Old Dec 28, 2006 | 09:11 AM
senicalj4579's Avatar
i have mine sealed up. having it sealed will alow the ssra to work better because the air has a more direct path
Old Dec 28, 2006 | 09:17 AM
Ragtop 99's Avatar
Doesn't the SSRA seal up to the lid?
FTRA comes with a rubber strip that blocks off the opening so that all air comes through the FTRA.
I left my hood alone.
Old Dec 28, 2006 | 09:53 AM
yep. ssra has a block off just like ftra.
Old Dec 28, 2006 | 12:52 PM
Magnet's Avatar
ok thanks guys i sealed it up
Old Dec 28, 2006 | 12:58 PM
Ripper415's Avatar
this may be a noob question but....how exactly does the hood scoop funnel air to the airbox? i looked under the hood and theres some small slits coming out the back of it. i assume thats where the outside air is coming in but it doesnt look like that hooks up to anything. so if its just bringing in air and swirling around the general engine area, how can it add more hp, or does it basically just help to cool things down in there.
Old Dec 28, 2006 | 02:20 PM
BayAreaSS's Avatar
I have slp cai and i didnt seal off the air box. I thought the more air the better.
Old Dec 28, 2006 | 03:16 PM
nexvctm2001ss's Avatar
AGREE!!!
Old Dec 28, 2006 | 08:09 PM
Magnet's Avatar
the only logical thing i could see is that the air coming from the SS hood is heated because its not a direct path, so sealing it off allows better suction from the SSRA and colder air
Old Dec 28, 2006 | 09:03 PM
Ragtop 99's Avatar
The expectation of sealing is that there is a mild pressurization once the car gets up to 30 or 40 mph. With high overlap cams, a slight increase above ambienent pressure on the intake could be pretty helpful.
This could all be BS, but I've seen consistent results at the track with sealed FTRAs of a 1 mph gain.
