Exhaust install problems...
Old Dec 27, 2006 | 09:15 PM
Loochy88's Avatar
Default Exhaust install problems...
I was working on taking off the stock exhaust tonight (99 stock z28), and immediately hit a snag. I was taking off the bolt on the wide clamp where the catback attaches to the y pipe. That bolt was rusted so bad i had to use a ton of pb and then rethread the bolt with a tap and die set. anyway, i got the nut loose, but it cracked horizontally, so the other half of the nut was still there holding and siezed to the clamp, and theres so little left i cant get a socket around it.
i guess its time to take it to the shop to have it done. i thought about cutting the clamp and buying a new one, but i looked up the part number and it says its part of the exhaust package. i dont know exactly what size clamp to buy and exactly what kind, or who would carry it. if anyone else knows it would help a bunch.
also, to you guys who have welded your exhaust up, do you typically weld the connection at the y-pipe/catback, or do you leave that clamped just like it is stock?
Old Dec 27, 2006 | 09:30 PM
brad8266's Avatar
what exhaust are you installing?
Old Dec 27, 2006 | 09:46 PM
Loochy88's Avatar
hooker 3 inch
Old Dec 27, 2006 | 09:57 PM
brad8266's Avatar
Ok, hooker headers and Y pipe or what?
Old Dec 27, 2006 | 10:11 PM
Loochy88's Avatar
just the catback.
Old Dec 27, 2006 | 10:16 PM
bene's Avatar
Trunion King
I got mine welded...
Old Jan 2, 2007 | 01:13 PM
lsx24's Avatar
Most of the time it's welded, but you can request a flange be put in as an option, since the stock ypipe is 2.5" I believe and most catbacks ipipe are 3"? If they are the same size you can use any type of band clamps.
Old Jan 2, 2007 | 05:20 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
yes, the stock chamber pipe is 2.5 inch and most aftermarket chamber pipe are 3inch.
when i did my catback... the heat sometimes weld that nut to the pipe clamp.. i had to get someone to torch it off for me.
 Michael S. Palmer
