fuel pump
Old Dec 28, 2006 | 10:42 PM
camross998's Avatar
Default fuel pump
I check the fuel pressure on my car and it at 30 psi. I want to know is it possible that if your fuel pump has a bad ground it could not work right. because I had a 1995 impala ss and the fuel pump was not putting out enough psi and i thought it was the fuel pump but it turned out to be the ground was bad. so what i want to know how could i check the voltage of the pump on my 1998 z28 or is it just that the pump is bad. because I'm runing lean in b1 and b2
