ATI Superdampner Question
Old Jan 3, 2007 | 08:11 PM
2000LS1TA's Avatar
Default ATI Superdampner Question
I was just wondering if I need to get a new / different crank bolt to run this pulley.
Old Jan 3, 2007 | 11:11 PM
The1N_only's Avatar
Yes, you need need a new bolt because the factory on is torque to yield. Yes the factory bolt will still work with this pulley. I hope that helps
Old Jan 4, 2007 | 05:09 AM
vettenuts's Avatar
Get a hold of the instructions and make sure you have means of meeting the interference fit requirement. I have one on the Vette and they require a 0.0007 - 0.0009" interference fit. This requires you have the tools to measure to 1/10,000". This is for the steel hub Vetter ATI pulley, not sure which one you are considering but make sure you look into this prior to purchase.
On a side not, I also pinned it. The ATI hub already will have a keyway cut into it and their pin kit is great. Lastly, once pinned, the ARP bolt is nice because it is not a TTY bolt but is rather tightened to 190 lb-ft using ARP Moly Lube on the threads and washer. Later removal is a snap. Make sure you build a tool for install as well, don't pull it on with the threads.
Old Jan 4, 2007 | 05:33 PM
2000LS1TA's Avatar
Thanks for the info guys, I have the pin kit and I have a "mike" for measuring. Do any of you guys have the part# for the ARP bolt?
Old Jan 4, 2007 | 05:59 PM
vettenuts's Avatar
Can't find it, but Thunder and several others carry it. You can also download the ARP catalog and find it in there.
Old Jan 4, 2007 | 08:15 PM
2000LS1TA's Avatar
thanks for all the info guys
