dynomax bullet questions
Old Jan 4, 2007 | 08:23 PM
jares99's Avatar
Default dynomax bullet questions
Does anyone know if it is possible to run dual bullets at the rear havn't gotten under to measure but it looks as if the 12" ones would fit I have a loudmouth exhaust and am getting headers and ory soon would like to quite it down a bit over running a single bullet whre the resonator is. Has anyone tried this or have input on it
Old Jan 5, 2007 | 05:25 AM
BirdmanLS1's Avatar
Well im doin tru duals over the axle and ill have dynomax bullets over the rear. Might be a bit different but ill post pics when the setup is done in 2-3 weeks.
Old Jan 5, 2007 | 11:44 AM
lsx24's Avatar
Just adding bullets are not going to quiet the exhaust down a whole lot. You'de be better off buying a 1-in 2-out magnaflow muffler only and welding it in place of where the resonators are. That will quiet your exhaust down much more. Then you'd basically have a Magnaflow catback. Bullets are basically straight pipes they don't do as much to really quiet the exhaust, but they do help rasp.
Old Jan 5, 2007 | 08:58 PM
jares99's Avatar
should help the cackle noise when I lift off the throttle shouldn't it
Old Jan 5, 2007 | 10:01 PM
mvvette97's Avatar
yes it will help alot. My vette doesn't have any cats and I also have Borla straight pipes. It was WAY to loud. I put a couple 12 inch dynomax bullets where the cats used to be. It's alot quieter at normal driving but it does get loud at WOT but has very little rasp.
Old Jan 6, 2007 | 08:30 PM
jares99's Avatar
thanks for the input mvvette97 thats more what i was looking for sound wise I will probably put them where the cats were when I do headers if they wont fit at the rear
Old Jan 6, 2007 | 08:34 PM
LSGunZ28's Avatar
I was also thinking of the rear.... I just installed a singe bullet today in the place of the LM1.... There is a difference, however it isnt a big one....
The difference is with the Dynomax, you get less rasp... But there still is plenty of rasp. Just less than the LM1... Also it sounds a bit deeper on idle and at WOT its still mean as hell!
