Which Kooks should I get?
BTW those sparco's look killer I am going to get some evo XLs this year and I was wondering did you use the sparco rails if so how were they?higher or lower etc?
Unless you are planning above 400ci I would stick with the 1 3/4. You'll trade a lot of midrange (sometimes 30#s torque) for "maybe" 5-10 above 6Krpm.
What if you planning a 383 like me? I thought more cubes were a good thing with 1 7/8s? I didnt know it had to be 400ci or bigger to get the benefit of having the bigger headers.
What if you planning a 383 like me? I thought more cubes were a good thing with 1 7/8s? I didnt know it had to be 400ci or bigger to get the benefit of having the bigger headers?
If you are running a blower I would go 1 7/8th for sure on stock displacement. 7#s of boost is effectively increase your displacement by close to 50%.
You want to maximize area under the curve and not just peak RWHP to go fastest. Especially in the heavier f-body's we drive. (We aren't drag racing 2500 pound cars with 5.13 gears and 5000 stall converters turning 8000prm)
From what I've read and what Kooks recommended, this should be more than ample for my setup.
And...I understand that 1 7/8" are a little harder to install...and might require some modification to the K-member, etc...
Good luck with your decision!
