Cats
Old Jan 7, 2007 | 03:37 AM
98goldz28's Avatar
Default Cats
I did a search but could not find if any companys that make cats that would work with long tube headers. I have a set of Pacesetter LT's. Do you guys know of any manufacture that might make something that would work and not drag on everything?
Thanks in advance
Old Jan 7, 2007 | 03:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Any high flow metallic cats.
Old Jan 7, 2007 | 04:10 AM
98goldz28's Avatar
But will they still give me the clearance? I had high flow cats and I scrapped on driveways, all speed bump even trying to go slow. Its a tight sob under there but I am sure you guys know that.
Old Jan 7, 2007 | 07:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Are you slammed? That is the question. If so it might be something that a shop will need to bend and install. You don't want to install them too far back or they will not operate correctly. What size pipe do you have?
Old Jan 7, 2007 | 08:07 AM
98goldz28's Avatar
I am running Pacesetter Lt's 3in off road pipe, with a magnaflow catback. I am not slammed but do have 1in lowering springs. The passenger side like I said fits ok but the driver side having the LTs is just a lil tight. I just need a smaller diamater cat. I saw mag, has these and I also found these
What do you guys think would work the best?
Thanks
Old Jan 8, 2007 | 01:23 PM
lsx24's Avatar
Thanks
The first ones would work good. They are most likey ceramic core, which would give up only a few hp to metallic core. All cats would work with long tubes, no problem. You just have to get the right diameter, most likely 3", to fit with the header collector.
Old Jan 8, 2007 | 01:47 PM
98goldz28's Avatar
I just need something that is going to fit under the car and not drag. I took them off because of that problem but the ones I got were hiflow but normal size.
