weird noise??
Old Jan 22, 2007 | 09:33 AM
lastcall190's Avatar
Could be, my TDs banging isn't constant either. Some mornings it's there at idle, others, not.
-J
Old Jan 22, 2007 | 10:44 AM
jlashley2001ss's Avatar
ok hope this makes sense.....I heard the same noise when I had my TSP-Y pipe w/ cats and hooker catback. Well now I have TD's w/cats and its still doing it. The exhaust shop kept my TSP Y pipe section with the cats unchanged, but after the cats he did the True Duals. It may be the Y-pipe section hitting?????? comments/solutions?
Old Jan 22, 2007 | 11:07 AM
Just may be, do you have poly mounts? I'd crawl under there and take a look at the "suspect" areas, that is, areas that are insanely close to the body. I remember seeing Blur's setup, and he had <1/4" in some spots, and with poly mounts he said he was getting NO contact, just a thought.
-J
Old Jan 22, 2007 | 11:09 AM
you talkin bout poly motor mounts? i have stock trans and motor mounts.
Old Jan 22, 2007 | 12:20 PM
Yes sorry, poly motor mounts.
Old Jan 22, 2007 | 01:14 PM
yeah but who could i get to install some poly motor mounts for me?
Old Jan 22, 2007 | 01:16 PM
Yourself, from what I understand they are more time consuming than anything (headers should come off). I wont lie, I haven't even done 'em, but I'm just gonna wait until I do H/C since the headers will be off anyhow. I know shops also do them, but I'm not sure what the going rate is.
-J
Old Jan 25, 2007 | 11:16 AM
what is the going rate? What if I just had my Pipe after the headers to the cats refabbed with more clearance?
Old Jan 25, 2007 | 11:56 AM
I know a few shops locally quoted 400 bucks to install. Mainly because it involves taking lots of **** off I believe.
-J
Old Jan 25, 2007 | 01:54 PM
lsx24's Avatar
Kinda sounds like cat shields. Also could be exhaust is hitting against the trans, or exhaust is hitting against the floorboard. Get under there and check the clearance of those two items while the engine is idling.
Old Jan 25, 2007 | 02:07 PM
thanks guys
Old Jan 25, 2007 | 02:12 PM
  #32
JoeyAnderson's Avatar
Check your flux capacitor, it could be contacting your shifter linkage, causing a similar sound.
Old Jan 25, 2007 | 04:00 PM
  #33
Good call... you been past 88mph lately?
-J
Old Jan 25, 2007 | 10:38 PM
  #34
BirdmanLS1's Avatar
Seriously look into the cat sheilds. I had a weird vibration noise at idle and certain rpms so i took it to the dealership and they charged me 1800 to rebuild the rear end, only to leave the dealership w/ the same vibration So i took it home, looked at it myself and it was the cat sheild... Needless to say that's the last time i ever took my car to the dealership.
Old Jan 25, 2007 | 10:39 PM
  #35
did you remove the cat shields??
