AIR removal ?
Old Jan 13, 2007 | 11:16 AM
WS6Wally00's Avatar
Default AIR removal ?
So last night I installed race style pacesetter LTs, TSP cattey Y, and LS6 intake manifold. I deleted the EGR and AIR but I have a few questions. Do you need to remove the fuse and relay for the sec air inj, and if so, where is the location of the relay? There also is a small solenoid on the driver's side bank towards the rear of the motor which I believe is for the air but not sure. However, there were small vacuum lines that ran from that solenoid to a cylindrical black valve that was part of the air. What do you do with the vac lines? There was a line on the back of the intake manifold that I reconnected but don't know what that is for either. Thanks for the help.
Old Jan 13, 2007 | 02:59 PM
jetlag's Avatar
The vacuum hose on the back of the intake manifold..just go to AutoZone and buy some vacuum hose caps.
I pulled the fuse for the air pump..it should give you a diagram on the top of your fuse fox showing what each one does.
