Insane Rattle
Old Jan 17, 2007 | 08:21 PM
Ahmadi6490's Avatar
Default Insane Rattle
Since i've gotten my Pacesetters and y pipe installed I have had a rattle issue that keeps getting worse. In 1st and 2nd gear, mostly on an incline it'll rattle right under the center console and passenger area like my tranny is going to drop. Today it's starting to drag into 4th gear at low rpms.
I got under the car a few days ago and tightended all my header bolts, their all still very tight. I looked around and shook the piping and it wasen't hitting anything. I do have a heat shield above my straight pipe where the cat is supposted to be but I doubt its that. I did notice my y pipe is touching my tranny housing but it wouldn't wiggle loose or anything.
Any help guys? This is making me not want to drive my car much. Btw when I turn the steering shaft it slighty pushes up against my driver side header but theres no change in my handling, I just noticed it under the hood.
Old Jan 18, 2007 | 12:31 PM
The PAT WS6's Avatar
is the y-pipe hitting anything under the car at all
Old Jan 18, 2007 | 03:04 PM
Sh4Dy's Avatar
I would say this is the problem.
You should be alright but you may want to put a little dent in the primary just to be safe.
Old Jan 18, 2007 | 04:20 PM
Ahmadi6490's Avatar
Thanks guys, I found out the mid pipe was sitting on the crossmember brace and just rattling away there.
