code P410
Old Jan 18, 2007 | 09:52 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default code P410
after 3 years of having my headers installed and 3 years of havening to erase this AIR P410 code w/ my tuner i'm tired of doing so. has anyone ever had this code after doing LTs, hi flow cats and y pipe system?
what causes it and how do i get rid of it for good?
Thanks
-Charlie
PS i also get a P1539 and 1546 code to. something to do with a voltage problem with my MAP sensor...
Old Jan 18, 2007 | 04:16 PM
2001NBMZ28's Avatar
For P0410 first thing to check is the air pump fuse under the hood - that is if you kept your air system. You can look it up along with the others for your particular year at gearchatter.com.
Old Jan 19, 2007 | 08:38 AM
is the fuse in the fuse box(duh) OR on or by the pump itself?
Thanks
Old Jan 19, 2007 | 09:17 AM
DBUS6's Avatar
There is also a relay under the hood in the fuse box!!
Old Jan 19, 2007 | 09:23 AM
TheBlurLS1's Avatar
That's what she said...
DTC P0410 Secondary Air Injection (AIR) System
All codes are listed in this thread.....
https://ls1tech.com/forums/generation-iii-external-engine/509539-water-got-up-intake-what-now-all-diagnostic-trouble-codes-dtcs-inside.html
If the guy can't disable a code that you have the damn name of, he needs his tuning software taken away. I still have the fuse (and relay if there is one) for my AIR system, and it's been yanked for about 2.5 years with no problems.
Old Jan 19, 2007 | 10:11 AM
MjMaro's Avatar
https://ls1tech.com/forums/pcm-diagnostics-tuning/609283-throwing-po-0410-code-help-needed.html
