Header Question
Old Jan 24, 2007 | 09:10 PM
02SLPCAMARO23's Avatar
Question Header Question
I Just Bought A Set Of Pacesetter Headers With Off Road Y Pipe. My Question Is What Else Do I Need To Install Them. I Also Have A Diablo Sport Tuner So I Can Delete The Rear O2's.
Old Jan 24, 2007 | 09:18 PM
dpw41285's Avatar
beer, block of plates for !air !egr, beer, patience and your normal tools. no need to get the header bolts
Old Jan 24, 2007 | 09:20 PM
musclebird69's Avatar
and some 02 extensions plus gaskets if yours are too old.
Old Jan 24, 2007 | 09:22 PM
brad8266's Avatar
Get the car up real high, so big *** jacks are needed or a lift. 10mm rachet end gear wrench. New spark plugs. O2 extentions unless youre gonna extend the wires yourself.
I recommend that you install poly motor mounts while the exhaust is already off too.
Old Jan 29, 2007 | 09:17 PM
I Only Got 17,800 Miles On It So I Am Good To Go On Plugs. But You Did Answer My Question About The Extensions I Do Need To Get Those. I Will Put Them On Next Weekend After I Get Some Cash And Sorder Some New Gaskets. I Also Got To Figure Out How To Delete The Rear O2's. Do You Think That Would Be Best Or Just Get The Sims?
Old Jan 29, 2007 | 11:39 PM
JKDZ28's Avatar
I reused my GM MLS gaskets and factory bolts - no leaks.
